Adventures in plastic. Polypenco pipes?
Place to blether and haver ;-)
bear
Post by bear » Sun Oct 04, 2009 7:36 pm
I'm looking for a (cheapish) set of pipes that I can play now and again for busking, the odd pub gig and impromptu session when I'm out and about and other occasions when I don't want to have to take my big flashy set of Fletchers out. I've been offered a set of Polypenco pipes. Anybody here play a set or know anything about them? What is the difference in sound between plastic and blackwood drones? Or should I just spend a bit more on a battered old set of 78th-hand pipes off Ebay? :)
Simon 'Bear' Addison. Piobaire Extraordinaire!
Greg_in_London
Post by Greg_in_London » Sat Nov 14, 2009 11:57 am
They have quite a good reputation, although the only person I knew who had them, well I didn't think they sounded good. Nobody else seemed to mind though.
For the purposes that you suggest they should do just fine.
better sharp than out of tune
stickmagnet
Post by stickmagnet » Fri Dec 11, 2009 9:15 am
Poly Pipes hold many advantages vs. Blackwood; but this needs a little clarification.
1. Poly pipes are nearly "nuke proof" - they don't crack, chip or become brittle.
2. They don't require oiling
3. They are waterproof - something that is a huge factor for the folks in Europe.
4. Easily "alterable" for things such as the "Little Mac" valve.
5. Did I mention that they are nearly nuke proof?
6. You can get them with "O-Rings" vs. wrapping help.
7. All the cool stuff for "Real" pipes, works with the Poly's too.
Drawbacks of Poly
1. They are very thick and can sonld a bit less "crisp" that a well running wood set of pipes - though the greatest spoiler is the REEDS one chooses vs. material; wood vs. poly.
Poly pipes are not a "beautiful" set of pipes most of the time
weather seems to bother them little
Hope this helps,
stickmagnet
The mind that is altered, alters all.....
P.M.'s are switched off
PipeSgt
Re: Adventures in plastic. Polypenco pipes?
Post by PipeSgt » Thu Jul 27, 2017 1:37 pm
I have a friend that left a set of polypenco pipes in his car on a hot day. He leaned them up on the seat, and they now have a bend in the bass drone that they cannot straighten out. I have heard that the polypenco pipes have a nice sound. I have a polyenco blowpipe stock tied into my pipe bag. They don't crack like the blackwood stock that in there previously.
