Adventures in plastic. Polypenco pipes?
Place to blether and haver ;-)
bear
Postby bear » Sun Oct 04, 2009 7:36 pm
I'm looking for a (cheapish) set of pipes that I can play now and again for busking, the odd pub gig and impromptu session when I'm out and about and other occasions when I don't want to have to take my big flashy set of Fletchers out. I've been offered a set of Polypenco pipes. Anybody here play a set or know anything about them? What is the difference in sound between plastic and blackwood drones? Or should I just spend a bit more on a battered old set of 78th-hand pipes off Ebay? :)
Simon 'Bear' Addison. Piobaire Extraordinaire!
Greg_in_London
Postby Greg_in_London » Sat Nov 14, 2009 11:57 am
They have quite a good reputation, although the only person I knew who had them, well I didn't think they sounded good. Nobody else seemed to mind though.
For the purposes that you suggest they should do just fine.
better sharp than out of tune
stickmagnet
Postby stickmagnet » Fri Dec 11, 2009 9:15 am
Poly Pipes hold many advantages vs. Blackwood; but this needs a little clarification.
1. Poly pipes are nearly "nuke proof" - they don't crack, chip or become brittle.
2. They don't require oiling
3. They are waterproof - something that is a huge factor for the folks in Europe.
4. Easily "alterable" for things such as the "Little Mac" valve.
5. Did I mention that they are nearly nuke proof?
6. You can get them with "O-Rings" vs. wrapping help.
7. All the cool stuff for "Real" pipes, works with the Poly's too.
Drawbacks of Poly
1. They are very thick and can sonld a bit less "crisp" that a well running wood set of pipes - though the greatest spoiler is the REEDS one chooses vs. material; wood vs. poly.
Poly pipes are not a "beautiful" set of pipes most of the time
weather seems to bother them little
Hope this helps,
stickmagnet
The mind that is altered, alters all.....
P.M.'s are switched off
PipeSgt
Re: Adventures in plastic. Polypenco pipes?
Postby PipeSgt » Thu Jul 27, 2017 1:37 pm
I have a friend that left a set of polypenco pipes in his car on a hot day. He leaned them up on the seat, and they now have a bend in the bass drone that they cannot straighten out. I have heard that the polypenco pipes have a nice sound. I have a polyenco blowpipe stock tied into my pipe bag. They don't crack like the blackwood stock that in there previously.
Return to “Bletherin”
Who is online
Users browsing this forum: No registered users and 1 guest
