Chariots of Steel
Chariots of Steel
Post by david n. siegel » Thu Apr 29, 2004 5:20 am
Not sure I'm done with this--may want to modify the repeat on the 4th part. Wanted a strong tune esp. for pipers who can hit low Gs with a firm reed.
1 March2-4 CHARIOTS OF STEEL .bww
4 pt. 2/4 Chariots of Steel
(3.75 KiB) Downloaded 928 times
awpiper
Post by awpiper » Wed May 05, 2004 11:59 pm
Very nice tune.........However you may want to check your timing on the last bar of each part.....it does not measure 2/4......You have a 1/32 note on the double B, a 1/8th note with hold on a E, a 1/32 note tied to previous E, a G Grace note and a Low A 1/8th note.....the grand total would be 3/8 timing........But, if you change it to the 3/8 time signature you lose the "effect" of the tune in that bar.........Mark
Bloo
Post by Bloo » Thu May 06, 2004 12:32 am
If you change it to this, it fits fine without loosing the effect and the timing is correct.
dbb Br_32 ^ts El_16 'e El_8 ^te gg LA_8
Cheers
B
Post by david n. siegel » Thu May 06, 2004 6:04 am
Thanks for the note and recommendations--I'm going over it again.
Always dangerous to proofread one's own stuff.
-david.
